Corolla S 05 with +130,000 miles
Battery terminals had heavy corrosion, so I decided to clean them with baking soda and water. After finishing up, I applied petroleum jelly around the terminals to prevent the problem from reoccurring. Went to turn on my car and forgot the keys in the ignition which killed my 08/11 battery. Jump started it and noticed a violent shaking when the a/c was turned on. It eventually died again, so I thought maybe it was the dead battery causing it to shake. Bought a new one and applied the same substance to the terminals after installation. Turned the car on to see if everything was fine, and the shaking happened again. So I'm assuming it isn't the battery at this point. Is it the jelly I put over the terminals? It was my first time trying it. Or was it all just a bad coincidence and time for a tune up? Any ideas? Thanks guys.
