RobbS
You are great. Thank you very much. On my way out to play with it.this was a google search...
The CMTOOL engine oil tester is a handheld, portable tool designed to check the quality of engine oil by measuring its transmittance (light passing through) and temperature via a probe inserted through the dipstick hole. It analyzes degradation to determine if oil needs replacing, helping identify contaminations, impurities, and oil breakdown in both gasoline and diesel engines.
View attachment 332208Ubuy France +2
Key Features and Functions:
How to Use:
- Oil Quality Assessment: Detects deterioration by measuring oil transparency/light transmittance. It provides warnings if the oil is severely contaminated or degraded.
- Dual Mode: Allows users to select between gasoline and diesel engine oil profiles for more accurate measurement.
- Digital Display: Features a backlit display showing an analog bar graph, temperature, and a clear breakdown of oil status (e.g., OK,
Δ
, X).- High-Precision Sensor: Measures oil temperature (range:
-10∘C
125∘C
) to help monitor the working status and load of the engine.- Long Flexible Probe: Comes with a
∼31.5
inches) corrosion-resistant Teflon hose/probe to easily reach the oil pan.
View attachment 332212Amazon.ae +4
It is recommended to use the tool when the engine is cold to avoid potential burns.
- Turn On: Long-press the ON/OFF button, select your engine type (gasoline/diesel), and choose temperature units.
- Test: Insert the probe into the oil dipstick port, ensuring it is immersed.
- Analyze: Press "Start" to measure; the screen will display the percentage of light transmittance to indicate oil health.
- Results: A high percentage means clean oil, while a low percentage (below 30%) indicates severe degradation, typically signaled by a red light warning.
View attachment 332216Amazon.ae +3
View attachment 332215YouTube
Thanks again
