Originally Posted By: red7404
i have a 01 dakota V6. is not driven much. i do have a OLD marvel mystery oiler on it. i found the oil level over full by 1.5 QT. what iam worried about is if the oiler is set wrong. what my BIG Q is . is there an easy way to see if my engine oil has been thinned out. of course the thing to do is change the oil. then be more careful on the oiler settings.
Is it a Marvel Inverse Oiler being set wrong? Probably if the level in the oiler went down by 1.5+ quarts quickly. My comments are based on you having one. If so you can check the flow by counting the drips per minute via the sight glass. You want about 15 or so drips per minute at an idle for a V6 engine. For that to flow 1.5 quarts and it end up in the sump there's something wrong big time. How many miles ago was the oiler filled? You want about a quart consumed/1,000 miles
With regard to the oil being thinned, if it drew into the sump 1.5 quarts of MMO the oil is thinner that it was when new.
