Engine Oil Drain Plug Replacement Interval
CA
I've noticed that for some german cars, specifically the VW/Audi cars, some enthusiasts recommend replacing the drain plug at every oil change, or at least on somewhat of a regular basis. Not sure why, but that just seems to be what they recommend.
I decided to get a new drain plug for my Saturn after 150k, mainly because my friend needed another item for his order to go over a certain amount.
However, have any of you replaced your oil drain plug for normal maintenance?
Leave it up to manufacturers of cars for rich people, always trying to milk an extra buck. I see no reason whatsoever to change the plug at each OCI. Heck I have had the same plug on cars for 150K as you have. No problems.
The '94 LS400 with more than 250k miles still have the same old drain plug and the same old drain pan and gasket. I think the saying "if it didn't brake don't fix it" is applied in this case.
Originally Posted By: SLCraig
If it ever leaks, is when it should be replaced.
Why else?
I've never replaced one.
The head of the bolt seemed a bit rounded off from wear.
Also, the threads were starting to get a bit sticky for some reason.
Why else?
just use a 6 point socket then.
Perhaps they replace the plug to stop the oil running back out?
I have never had to replace a worn drain plug.
The crush washer and drain bolt is separate on my car. The washer is still factory but I have a replacement waiting should the black crush material is all gone.
Its was only $1 or maybe $2 from the sealership.
If it was round off, just replace it, but why is it round off to begin with? I though you have $1k worth of Snap On and that's not suppose to happen.
I've never been or ever will be that enthusiastic. Plug not rounded off, good to go. Interval being, if it's not broke, don't fix it.
