When my dad used to change the oil on the Saturn, he used a soft fiber/cork gasket on top of the rubber o-ring whenever he changed the oil. He replaced that homemade fiber/cork gasket at each oil change and it worked just fine until recently. Suddenly, I began to see some slight seepage from the plug area. Not enough to land on the floor, but just enough to get the oil pan area wet.
Now, I took over the oil changes. At the last oil change, I installed a new o-ring from NAPA on the drain plug. I did not use any homemade gasket. I tightened the plug. On Sunday, I was at the shop and the technician and I both noticed that the drain plug area is wet. Again, just wet, no drip on the floor.
What's the cure? Also, if this helps, the oil drain pan has a "groove" that is outlined by someone overtightening the drain plug at one point. However, I've had the groove for a very long time and the oil leak issue did not appear until recently.
Thanks.
Thanks.
