Reference the 2000 F250 in my signature:
I am not having good luck right now. The knocking from the rear axle I have posted in a separate post has now been placed on the back burner.
So, my engine has always made noise, I never paid much attention, figuring a high-mileage engine was entitled to make a little noise if it wanted to. However, I noticed yesterday that the engine is actually making a noise which sounds like a cross between a rod knock and valve train tapping. At idle, it is quiet. Revving the engine in Park, the noise sets in with a vengeance around 1800 rpm. It is not terribly loud, and the volume does not change with rpm. Above 2200 rpm, the noise is still there, but does not seem as intense.
To see if it disappeared under load, I held it in first gear and listened closely. The noise again kicked in at 1800 rpm. I held it in 2nd gear, same thing. In 3rd gear, I can't make it out over the road/wind noise. It is present whether the engine is hot or cold.
Crawled under with a stethoscope tonight, with the engine held at 1800 rpm, and the noise is definitely coming from the engine block on the driver side. In the stethoscope, it sounds like a harsh metallic tapping, very rapid. I checked the valve cover, timing chain cover, heads, oil pan, and bell housing. It was only heard on the driver side of the block when using the stethoscope.
Does this sound like wrist pin(s)?
