First off, 2004 Mazda 3, 2.0L Automatic 4-speed, 73,000 miles
Noise has developed over the last few thousand miles. It's always hard to explain a sound, but I would say it almost sounds like noisy injectors or almost like a diesel engine, just a constant small rattle. A few interesting notes...
-- Only happens in 4th gear, with slight pressure on the gas pedal. I can adjust how loud the noise gets to a point by gas pedal pressure. It will be very faint if I just barely have pressure on the pedal, if I put a little more pressure the sound gets louder. However, if I put a moderate amount of pressure on the pedal, the car will rev from about 2000rpm to 2700rpm (normal). The instant the rpms move up due to moderate pressure, the sound dissappears.
-- The sound happens with an ice cold engine, and also with a fully warmed engine. Thus, can happen at any time.
-- Sound never happens at idle, startup, or 1st through 3rd gear. Only time is in final gear, with very little gas pedal pressure.
Since I can somewhat control the sound through light pressure on the pedal, I would guess it has something to do with fuel injection, or maybe a valve adjustment?
Finally, car uses Shell Gasoline, and is normally treated with Redline Fuel Treatment, so adding fuel injector is not the solution certainly. At any rate, what's your opinion?
