EDIT expired:
Originally Posted By: lipadj46
Originally Posted By: Craig in Canada
Furthermore, I don't relish the idea of spraying "hot" oil all over -30C metal parts.
They don't really get the oil that hot but regardless if a cold engine can handle going from cold to combustion in a split second I'm sure warmed oil will not cause anymore undue stress. I get I would also disagree that starting with 6 quarts of warm oil in the sump on a cold morning makes no difference.
The combustion is in one place - inside the cylinder - and its expected by the designers that there will "suddenly" be combustion occurring there. The hot oil is going everywhere - valve train, variable valve timing gear, tensioners, tiny little passages through aluminum heads (which could be close to cracking with normal thermal loads in some engines) etc... and engineers/designers do NOT expect the warming to originate from there. Oil does more than lubricate the cylinders and cams these days.
This rebuttal was only against the one, most minor point? I didn't say it made NO difference, I said that it'll be cold again by the time it returns to the pan the very first time and all of the metal in the engine is still barely closer to normal operating dimensions. I think warming the oil instead of the coolant just makes people feel better because the starter sounds like it isn't working as hard against the oil pump.
On a cold -30*C night I'd rather warm the block to 10*C or even 0*C than just a puddle of oil to 60*C+ trying to achieve the same effect. A 10*C ambient fall weather start is nothing, and would certainly present lower wear, faster warm up, better fit of moving parts etc... than true ambient even if it isn't "warm" and providing instant heater operation.
I've never used any kind of heater and my winter wear is typically low single digit PPM of wear metals in 8,000km OCI even with mostly short trips. I think that attempting to prove that one kind of heater is superior for wear protection through used oil analysis would be difficult and pointless unless some of you are showing a lot more wear than that.
