I thought someone here might have some experience with this. on my 92 mitsubishi mirage, 115k miles, the car starts fine, I let the car idle apprx 30 seconds in cold temp, drive slowly, but when I get to the first stopsign and idle for a minute for traffic. the engine shuts off immediately. what would be the cause of this? I start the car right up on the first try with no problem. The problem doesn't happen again when the car is warmed up or stopped. is this as simple as a clogged fuel filter? I bought the car in 98 and no records of previous fuel filter change. however, I read that clogged fuel filters would cause the engine to die at high speeds not at low speeds as the demand for gasoline is greater at high speeds. thought I would run this by some folks here for some opinions. This is the second time the engine has died on me in the past two months. I use chevron gas and I cleaned the throttle plate back in July when I had an idle problem. any opinions greatly appreciated
