Of course not, nobody does this, it's a silly thing to talk about really. You accept that a vehicle that runs strong and doesn't have excessive oil consumption is "fine". We all do it and it's a reasonable assertion. Nobody is tearing engines down on their street/daily vehicles to check this. Yes, we all understand 30 gives more protection regardless, again, why not 40 b/c it always gives more protection over 30 regardless. You do b/c at some level "it's enough".xW-30 is going to give more engine protection regardless ... that's the whole purpose of stepping up a grade. I like headroom, not possibly running on the ragged edge in some situations. Have you tore it down to verify all the bearings are not showing any undue wear?
Sure/yes. And no, nobody is tearing down engines, neither are you or anyone else on BITOG in these discussions.Re: bold above. So you're saying you think a xW-20 would be fine for that car in track use just because it's a low-density engine? It depends on a lot more than just that factor. Any of your race folks ever tear open those engines used for track use with 20 to inspect bearings? Just because an engine doesn't blow a rod through the block doesn't mean it's wearing out faster.
You drive a performance car, not a mundane daily. So if you had a 2015 Camry, you would run 93 in it and upgrading oil grade to drive around town? Do you recommend everyone here the extra headroom 93 provides regardless of vehicle or use? That's the discussion here, not your Mustang or my track-wagon. This discussion seems to be 9/10 folks buying Kias, Hyundais, Toyotas sweating running "cafe water" 0W20s etc. and folks in the posts telling them to run a 30 or 40 grade. Won't hurt them for sure but it's just not hurting them to run the thinner oils b/c they aren't being used in conditions (most of the time I suspect) that it would ever matter. I'm surpised you are not running a 40 in that car but if you're just driving around town I can understand.Yes, I do on the Coyote V8 even though it will run on 87. I also run 5w30 instead of 5W-20 ... such a rebel !I made the switch to 5w30 way before Ford finally woke up and started specifying 5w30 not long ago for the Coyote in the USA. Apparently the switch to a higher viscosity by Ford was going to sacrifice CAFE credits for something better.
