I've started to install EHT3 pads/rotors on people's car who can afford to wait for rockauto to ship to me. Otherwise its just AAP or autozone.
I did two Toyota installs roughly 6-8 months ago. 2009 Camry and 2012 Corolla. Both owners mentioned to me an annoying squeak on the first brake and then it goes away. I find it odd because those two owners are not very detailed about their cars but they noticed and asked if it was an issue.
I mentioned the normal when the car sits in the rain or whatever the first braking is to clean off the rotors and etc... I offered to check everything out in case something was off. I lubed a few extra spots made sure piston and slide pins were good and went for the test drive sure enough the first stop does squeak and then no more.
I did take the care around the block and did some more heavy brake bedding to see if that would help. Seems odd, i've also installed a set on a mazda and no issues or complaints on that.
