JHZR2
Staff member
Hi,
My BMW is a 91 E30 3-series model. Came with sealed beam 5.75" headlights.
I plan to upgrade the relays/wiring when it gets warmer - but since I had the lights and it was nice today, I figured Id install them anyway.
I didnt use high voltage bulbs - just standard 60/55 for the lo-beam circuit and 55w hi-beams, just like the selaed beam light ratings that were in there before.
Recently, before I did this install, I had put in new fuses, all the correct amperages, as some of the OE ones looked kind of old and lousy (the fuse box is underhood, not in the car). I put new 7.5A fuses in for the hi-beam circuits... all was well, and it worked like a champ.
All I did was install the new lights. lo beams work great. Hi beams work great on the right side, but blow the 7.5A fuse every time. All the wiring is tight, I put dielectric grease on each connection, and everything was perfect at the same wattage bulbs in sealed beam form, not 20 minutes before.
Any idea what gives?
I did a test, and put in a 20A fuse in place of the 7.5A one. I waqs just going to be checking everything, so figured that all woudl be well, if I sensed the fuse getting hot, Id kill the lights. The lights worked very stable, without issue, for somewhere between 30 seconds and a minute, before I killed them because I sensed no wrong. The fuse stayed cool, and showed no sign of thermal distress.
So, any ideas? Im not comfortable with using a 20A fuse, but I would consider a 10 or perhaps even a 15A fuse in there as a stopgap solution. How terrible would this be?
Is there any sort of test that I can do to see what is wrong? An ohmmeter between the hot and ground on the lighting harnesses? Can I check the circuits at the fusebox to get an understanding of overall circuit resistance???
Also, given that there are already relays for the lighting circuits as OEM install, what would I want to do as an upgrade? Higher-rated relays? Would I perhaps only need to decrease gauge/increase wire diameter?
Any insight would be most apprecated.
Thanks,
JMH
Thanks,
JMH
