Originally Posted By: bob_ninja
Thus when a heat wave hits and ACs are pulling too much power form the grid, then the grid may send a signal to thermostats to increase temp setting a few degrees to reduce AC usage. That way they could avert overloading the grid.
The local electric company here uses load management switches (and has since 1979--they were one of the first in the country to start using them). The deal they offer is that if you allow them to install one (free of charge) on your electric water heater or central air conditioner, they will troubleshoot problems with that unit and fix them if they are minor.
The load management switches they use are radio controlled, I believe they operate on a VHF frequency in the paging band (somewhere around 140-160Mhz). They are configurable to one of 65,535 addresses. When they recieve a signal they disconnect the attached load from it's power supply for 15 minutes. In typical use the power company turns off 1/4 of the load management switches at a time, so if they need to control load for an hour all switches will have cycled for 15 minutes during that hour.
The load management switches also delay power-on for several minutes if the power is interrupted, which probably helps in a power outage.
