I have a 2010 Mazda 3 with the 2.0L naturally aspirated 4 cylinder. The car has about 14k miles on it.
The last oil change was done at Firestone with full synthetic Kendall motor oil and what looks like an Ecore filter (though they swore they used Purolator--nice!).
Anyway, that change lasted 6 months and right about 5k miles. I changed the oil last night, and it was putrid with fuel. The wife came out to the garage after I had it drained, and noticed the garage smelled of fuel. I couldn't stay under the car while it was draining. Yuck! It also came out looking pretty black. I refilled it with almost clear Motorcraft synth blend.
It's mostly the wife's car, though I drive it a lot when we both go somewhere. However, the car sees a lot of short trips (especially when it's just her). So I'm guessing that's where the fuel dilution is coming from.
So, I'm guessing I should change the oil on 3-4 month intervals, then? I guess subscribe to severe service? Are there any other measures I should take with the car, is this an indication of an early issue with it?
The car is spec'd for 5w-20. My truck uses 5w-30, so I get the Chevron dino oil from Costco when there's a coupon (buy 3 cases when needed). Would it be OK to use this in the car? It's about as cheap as it gets around here, and if I have to change it every 3-4 months, I don't want to spend an arm and a leg. I'm a little concerned about going out of spec, but the turbo 4cyl Mazdas require 5w-30.
Thoughts?
Thoughts?
