I was changing my oil today using Valucraft Ecore 3614 filter from Autozone and Rotella T 15w40.
Fired up the engine and the oil pressure light stayed on. (*** !?!) I tried revving the engine a little bit then the lifters started to tick. I took the filter out and there was no oil flowing though it. The center was still oil free...
I was thinking maybe the oil is a little thick although, I was using Delvac 1300 15w40 with a ST non-ecore filter.
I put the old filter back on and got oil pressure again.
Now... Whatcha think? I think the combination of Ecore filter and thicker oil caused this problem. I think if i was using 5w30, this wouldn't have happened...? I use thicker oil because it's a Saturn...and you should know the rest.
