https://www.eastpennmanufacturing.com/wp-content/uploads/Battery-Care-Maintenance-0004.pdf
Charging a 50Ah 100 minute RC rated AGM battery at 14.8V and 30A sounds very aggressive to me.
The maximum charge rate in amperes should be no more than 1/3 of the battery’s reserve capacity minute rating. If the terminal voltage exceeds 16.0 volts while charging, reduce the charge rate....
AGM 12-VOLT BATTERY CHARGING CONSIDERATIONS:
Not all chargers are really AGM compatible and can do significant damage to an AGM battery. Large “wheeled chargers,” found in many shops, which exceed 15.4 volts must be avoided. In the rare occurrence that an AGM battery needs to be charged outside of the vehicle’s charging system, charging voltage should be
13.8 –14.8 @ 77°F (25°C). Not to exceed 30 AMPS.
