Car is a 2007 335, rolling up on 198,000 miles. Been trying to chase down this vibration for quite a while. It seems to be a couple times faster than the wheel speed, sounds and feels almost like an aircraft prop. You can sort of notice it accelerating around 27-30 mph and really notice it 65-70 mph. It seems to lessen the faster you go, which seems odd.
A year and a half ago when the trans was out to replace the rear main seal, I looked at the driveshaft. It seemed good - tight u joints, solid rubber around the support bearing. Nothing obvious. This year I ended up replacing both CV shafts, one when I mauled it replacing a wheel bearing and the other just for yucks.
I'd like to run this car down to Kentucky over New Year's but I'd be happiest if I could figure out this annoying problem.
Should I throw a driveshaft at it? Maybe even a junkyard part?
