- Joined
- Jul 19, 2025
- Messages
- 14
I am new here but I have several car stories you might find interesting. In this case, I switched to E85 gas in my 2008 Pontiac Vibe. Some of you may know that the Pontiac Vibe is basically a Toyota Matrix sold by Pontiac. It uses the same Toyota engine as a Corolla of similar year.
I did not have experience with E85 other than what I saw on youtube, people using it for tuning high horsepower cars because it is essentially a very high octane type of fuel.
A few years back, gas was almost $6 a gallon in California. I read a story about a guy in france who used E85 in his Toyota Yaris for over a year with no issues because in his country gas was $7 per liter. So I started experimenting with E85 since it was only a bit over $3 a gallon. I raised the mix of regular gas and E85 to about 35-40% before the computer could not keep up with it anymore.
I tried to figure out I could get more fuel into the engine. For those that do not know, E85 requires much more fuel to be injected than regular gas. I then realized that the higher performing 2ZZ engine had higher flowing injectors and would bolt right in.
I picked up a set from Amazon for only 50 bucks and put them in. To my surprise, it worked perfectly with the amount needed to run E85. In fact, it was still putting in too much fuel. The computer eventually compensated and I daily drove it this way for almost a year.
There is a myth that E85 will kill your fuel lines and fuel pump, but in fact that never happened. When I bought a newer car, I gave the car to my mom. I had intended to put the regular injectors back in, but never did. Combined we have driven 60,000 miles on straight E85 over the years and it still works fine.
I still intend to put the original injectors back in, because gas is now $4 a gallon. So the $3 a gallon E85 is no longer a savings, in fact it is costing more now because with E85 you get poop gas mileage. Sure you can fill up the whole car for $20, but it only lasts about a week.
The only issue I had is that because the injectors are a big too large, you have to let the car warm up for about a minute before driving. The computer can't compensate enough when it is stone cold.
Also, we did run into an issue where they ran out of gas because they went on some wild trip and couldn't find an E85 station. Someone gave them a gallon of gas but of course that did not work well. I had to go get 3 gallons of e85 and deliver it to them so they could drive it again.
So next time you read a story about e85 corroding out your car fuel lines and pump, just tell them that is maybe not true.
