Can anyone say for sure from their experience if these ethanol treatments actually work? What exactly do they do? Do they actually protect the engine from the harmful effects of alcohol or just prevent water/alcohol/gasoline from separating? And how as little as 1 ounce can treat 10 gallons? And 1 ounce of another brand like “Ethanol Medic” can treat 16 gallons.
So far I cannot say none of my cars or small engines have suffered any “damages” from running E10. Such as the pump diaphragms in small 2 cycle engines or carburetors. Or rotted fuel lines.
I’ve been using Stab-il’s marine ethanol treatment and to some extent Ethanol Medic and Starbright in my lawn equipment and most of my cars. These cars are my collector cars that can sit for months without being driven. So I typically add something to it just to be on the safe side.
I have not been using anything in my ’03 Subaru which is driven more often but maybe I should. Not that I don’t care about it, just figured the real problem occurs when the car is not driven regularly.
Something happened about a year ago and it crops up every now and then and wonder if it has anything to do with E10.
One day my Subaru started to buck around 3K rpms every now and then. It doesn’t really seem like a misfire but more like a sudden loose of power yet the check engine light never comes on. The condition would crop up if the car sat for more than 2 weeks and below half a tank of gas. Once the engine runs for about 15 minutes (which has nothing to do with reaching operating temperature) the engine would smooth out. More like the fuel getting agitated by the excess fuel coming off the regulator going back to the tank. The problem seemed to have went away for a while.
Then a month ago I decided to run the tank down as low as I could so I could start out with fresh fuel and add some ethanol treatment. So I get down to about 3 gallons when the car starts running poorly. So I decided to just go ahead and fill it up. Initially the car still ran like poorly but ever since it has run fine. This time I added some ethanol treatment to it.
It’s my understanding that alcohol mixes well with gasoline however if any moisture comes in contact with the two, water will attract itself to the alcohol because it likes it better (Which is known as a azeotrope ) then sinks of the bottom of the fuel tank.
This same method is used in the chemical industry. If you want to separate acetic acid and water using less steam, introduce some Isopropyl acetate to the mix. The acetic acid and IPA mix and the water falls out and sinks to the bottom of the column then the IPA and acid go out the top and is pumped to a distillation column which can be separated buy distilling at a lower boiling point.
What I am wondering is an I experiencing the effects of this? So if the car sits for 2 weeks, the alcohol/water mixture sinks to the bottom and causes the engine to run poorly at first then as the car is run, all three mixes together and the engine smooths out? But looks like if that were the case the car would not even start.
