Is it possible to store E-10 fuel over the winter? It looks like E-10 only has a two month shelf life. Phase separation occurs from moisture.
Mercury Marine first recommends removing all fuel the tank, or adding a stabilizer and topping off the tank.
http://www.mercurymarine.com/serviceandwarranty/outboardfaqs/ethanol.php
I have 30 gallons mixed 50:1 in my boat. I can easily remove it. The local landfill/recycle center accepts oil, antifreeze, paint, but not gas. If I drain it, what do I do with 30 gallons of gas? If it was not 50:1, I'd put it in my beater.
Is is safe to store the tank full, or should I drain it?
