One day I woke up and battery was completely drained in 2020 Nissan Armada.
Worked fine before, nothing after sitting just overnight. No lights or accessories left on or anything like that. It would not start using a battery jump pack, would not start with a cable jump from a good battery. (Heavy gauge 10 foot cables). Also tried a jump from good battery to Armada cables removed from dead battery. (My boat batteries that I used had different terminals and was too large to connect in the vehicle). It did start after installing another new battery I have on hand to install in another vehicle soon.
Took it to the dealer. They diagnosed a bad battery and replaced. 2 weeks later, same issue.
They diagnosed bad battery and replaced again.
I asked them to check for parasitic drains and diagnose the charging system. They said it all checks out O.K.
I felt like there was something causing a problem and was not comfortable with just bad battery diagnosis twice (1st 2 batteries are at least 1 year different in age, so likely not just a bad batch of batteries, but they were from the same dealer, so maybe?).
They asked me if I do long or short trips. This car gets mostly in-town driving, short trips.
Their master tech recommended cutting a wire that prevents the alternator from charging all the time.
As was explained to me, they said there is a feature that does not start to charge the alternator until a certain minimum miles of travel is met (apparently to save fuel).
I am not sure I am buying this, but it has been a few weeks and have not had a return of the problem yet.
I am not a fan of these types of "fixes". Dealer said it will not void extended warranty plan I bought with the used vehicle.
