Both my brother and I have Toyota 4x4 pickups with 3RZ-FE engines.
Last year I did a overlanding trip in a desert region here in South Africa.(The dust there is very fine like baby powder!)
When I did a service not long after this trip, to my horror I found a fine layer of dust in my air intake that had made it past the filter?(FRAM paper filter)
The filter itself had dust in it but wasn't that bad.
My brother and I did a trip this last weekend and drove a lot of miles on dirt roads, he changed his air filter yesterday and noticed he has the same problem?(I haven't checked mine yet will check this weekend)
I usually put some red rubber grease on the rubber seal were the filter opening goes on to the air intake and after my experince last year I put a small piece of thick tape under the filter so it be pushed on tighter(I thought maybe the filter is moving slightly on badly corrugated roads and loosing it seal slightly?)
To me the design of the intake is stupid?
It sucks air from inside the right fender, there is a fender lining but there must be a lot of dust coming of the front wheel?
My other older Toyota pickup's intake sits behind the headlight which seems much better in my opinion.
I could fit a snorkel but they are very expensive and I do not like the idea of cutting a hole in the fender.
How serious is this small amount of dust that is getting through to the engine?
I saw a post on a local forum here were a farmer had the same problem with a newer Toyota pickup and when he told the Toyota agents they said not worry this small amount of dust wasn't enough to do damage!
I want to do a used oil analysis afer my next oil change to make sure.
