DuraLube Code Red
usa
So in my curious fiddling about I run across Dura Lubes classic line of additives that nobody with common sense would ever add to their vehicles, but I found this even more stunning...
'Dura Lube Code Red Engine and Transmission Conditioner'
Of course, Dura Lube's terrible website gives you little useful information so I looked it up online, eventually coming across it on Canadian Tire's website.
Quote:
Code Red engine and transmission conditioner helps remove sludge and rejuvenates older engines
Reduces friction and heat, and works in gas and diesel engines
To be added to engine if the red oil light is showing as a temporary fix between oil changes
177 mL
At least finally someone admits what all these glorified oil thickeners are for. Much as personally I think "between oil changes" should actually read "between engines".
I find it more funny thinking someone sees that red light and immediately walks to the potions-and-spells isle of an auto store and goes "hey! Just what I needed!"
"Now where's the stuff to pour on my brakes to fix that other red light I'm getting?"
