Originally Posted By: Colt45ws
Oh, one thing I noticed with duals is it downshifts less often. I have the same gears you do. There are a couple hills Ive tested this on. One on a 50mph highway would normally take a TC unlock in order to pull it. No longer.
On the interstate (75mph) a particular hill used to cause a unlock, then shortly after a kickdown to 3rd. Now it will just unlock but remain in OD.
This is all with cruise control on.
I call that a win in my book.
Sounds pretty sweet. The Walker system is 2" pipe with a regular H pipe much like the stock system. I will be doing some long drives in this beast about 1000 miles at a lick. If it is holding gears longer, it couldn't be killing torque. It sounds like it is pulling stronger. I value your analysis very much since we have essentially the same vehicle. I did a 21mm Ford sway bar with Moog end links. Its like a different vehicle. I am thinking about some Moog progressive coils in the back also. I think that would help the way it likes to squat with even a small load in the back. For $60 you can't beat that!
