427Z06..
You install your own filter right?
As long as whomever installs the filter cleans the mounting base where the gasket contacts the base, lubes the gasket, and not over torque's the filter...then it is more likely you can remove the filter without to much problems.
Where there is a problem is because someone didn't clean the base, or didn't lube the gasket.
Something quick lubes tend to be famous for.
The gasket itself in the filter is not tested by the filter company, and there have been "some" problems over the years.
There's always that bright University Engineering graduate going to save the company money and use a less expensive gasket. Reinvent the wheel as it were..they learn...
I once knew of an engineer who thought it a novel idea to put a pellet of diesel fuel conditioner inside the fuel filter to slowly dissolve because that way they wouldn't have to buy the kind you pour into the fuel tank. Brilliant the lad was...
btw ..as we're on the subject of gaskets. Ever notice the color stripe(s) on the gasket? Look around the outside edge. You'll see various color stripe(s). That tells the filter company if the right gasket is being used for the right application. They're not all the same for every filter..
