With regards to the comments about how fast the cars go, our Mach-E is a Premium AWD trim and I can't imagine anyone really needing to go faster than this. Magazine reviewers have tested this trim at times between 4.8 and 5.1 seconds 0-60. You can pull out into pretty much any gap in traffic confidently, that's really the only use case for this accelerating this quickly in normal everyday driving. I actually turned down the drive mode to "Whisper" in an attempt to make a little more efficient as we inadvertently had it in "Unbridled" mode since new. The car is actually more enjoyable to drive in Whisper mode because it's not trying to leap away at the slightest provocation of the go pedal or brake pedal. And it's still plenty fast to blow away from traffic with minimal to zero effort.
If you get a 2024 GT, it is 3.7 0-60, and if you pay for the software upgrade to the "GTPE" aka GT Performance Edition, that declines to 3.3 seconds 0-60. But why? You need slicks to take full advantage of it, I'm sure. I'm sure the GT comes with grippier rubber than our Premium AWD, but still, I can't imagine that it would do 3.3 to 60 without the conditions being nearly ideal for traction with the stock rubber. Any bumps, loose gravel, etc and you're breaking the tires loose for sure.
I'm already at the edge of traction with the Michelin all-seasons on our Premium AWD, a hard launch will break the tires loose briefly. I'd probably be fine giving up a second 0-60 as, 5.8 to 6.1 would still be fast. The torque in an EV hits different, it doesn't need to be as all out fast as a gas car to perform passing manuvers and so forth.
The point that
@JHZR2 makes is real, what happens when there are a lot of these out there and people are doing risky maneuvers on a regular basis. Our crash rates have already been going up. I don't have any really good answers in this area, other than, people need to take driving more seriously.
