JHZR2
Staff member
Hello,
Car is 1991 BMW 318i. I removed the cluster because of a jumpy temperature needle and need to service the service indicator board (common thing to go bad, as there are batteries on it).
Question is, can I drive my car without the instrument cluster? I have not tried to start it, but I assume it will start fine. The cluster is connected via three ~24-pin harnesses. Everything is electro-mechanical, there isnt a direct-piped oil pressure gauge or similar (like there is on my MB's).
The way I see it, so long as I drive slow, the only issue is the mileage I racked up without the odometer in there. I've filled up on gas very recently, and will only drive 20-40 miles in this configuration at most.
Any thoughts or issues?
Thanks!
Thanks!
