it's on a '96 ford bronco 4x4, front differential.
i don't see a drain plug.
i'm guessing that you would need an oil transfer pump to get the old gear oil out of the fill hole.
if this is the case, are the 12v. pumps you power from the vehicle's battery up to the task?
thanks.
thanks.
