Draining order for changing brake fluid
VA
I have a '98 LS400 and a '00 GS300. I am gonna change my brake fluid. What is the proper bleed order? RR, LR, RF, LF?
quote:
farthest to nearest
Farthest to Nearest is the usual way to go about it, and without other information it's what I would do.
There was a recent thread here from someone who had problems with his bleeding. Eventually, he took it to a dealer, and it turned out there was a different pattern to follow.
I don't remember what car it was without searching.. may have been an Audi ? ?
What's an LS400 and GS300 ? Lexus ?
My Subaru with abs lists the proper bleading sequence as RF>LR>LF>RR. THIS IS CORRECT FOR MOST VEHICLES WITH ABS. The reason for this sequence is so that contaminated fluid does not degress into the other lines, hense the first should be the shortest. Older cars without abs use the farthest first sequence. ed
quote:
What's an LS400 and GS300 ? Lexus ? [/QB]
yes, lexus
