Drained water heater today...
FL, USA
Good evening everybody, hope you have all had a good weekend thus far. Today I decided to attempt to drain our water heater. This unit is in our first house, a 1959 ranch that we purchased a little over a year ago. The water heater itself is a 30 gallon gas unit, and is around 21-23 years old if I remember correctly. It hasn't been drained in AT LEAST 9 years, as the house vacant for 8 years, and most likely it was never drained before that. I was nervous going into it knowing it hadn't been drained in possibly 23 years, worried that the sediment would block the valve, or that the pressure release valve would get stuck or break.
Well, thankfully the process ended up going smoothly. I dug down to the water meter and shut off the valve (for the first time since moving in) Once the water supply was shut off I turned the water heater thermostat off and turned the gas supply to "pilot". I had to then go purchase a new garden hose since the one we had was leaking water everywhere. Once the new hose wast attached I proceeded to opened up the drain. Not much happened so I went ahead and popped the pressure relieve valve open and had my wife turn on all the hot water faucets inside the house.
That worked like a charm and the water began flowing out. Once empty I closed it all back up and turned the water back on, filled it up, then drained once again.
After it was all said and done we ran all the faucets for a while to get the air out of the system and to flush the sediment out of the lines, plenty of little rust flakes and other debris came out. Especially in the original bathroom.
Glad to have that out of the way knowing now it can be done. Hoping the water heater will keep going strong with no leaks since some of the gunk was probably flushed out. It may just be the placebo effect, but the water did seem to heat up much quicker than before the drain.
My apologies, I put the wrong title. It should read "drained water heater today". Mods please fix if you can, thank you!
Originally Posted by JohnnyJohnson
Rust flakes and other debris came out.
LOL no pictures
No, I am sorry. Honestly by that point I was about to pass out from this Florida heat! I didn't think to take pictures. They were not large, most were the size of a large grain of sand. A couple were flecks that were the side of maybe half a finger nail clipping (yes gross I know, but that's all I could think of) haha.
If you have a water meter then I assume you have city water. Well water tends to have slight amounts of very fine silt. At least in homes I have owned. So if allowed the fine silt will settle to the bottom of the water heater. When you drain a water heater with silt on the bottom you get dirty looking water for awhile out of the drain hose.
There was no need to open the pressure relief. Opening a few faucets on the hot water side would allow the water heater to drain. Sometimes after opening the pressure relief and snapping it back closed it drips.
We do have city water, and thanks for the tip. I will try that next time.
Originally Posted by WyrTwister
As hard as our water is , anything past 10 years is fantastic . Wyr
My current water heater is going on 16 years old. I have never drained it. We have no water softener. Our water could be considered "hard". The last 2 houses we owned before this one both had water softeners. I never had a water heater last more than 5 years in either of them.
Also, another thing that surprised me, was when we had our evaporative cooler installed in our new house in Lake Havasu City, the builders there purposefully run a water line that bypasses the main water softener line. And instead they run a hard water line direct from the main, to the evaporative cooler on the roof. All the builders do this, and it requires substantially more plumbing depending on where your main comes in, along with how your house is laid out.
I asked the outfit who did the install why, and he told me if you run soft water to any new evaporative cooler, it will automatically void the warranty. And it won't last half as long. It has something to do with electrolysis and the salt used to clean the softener when it regenerates. While the backwash cycle gets most of it out, it doesn't get it all. Which is why they say you should never drink softened tap water. (Ours was run through an reverse osmosis system that fed the kitchen sink, as well as the ice maker and cold water dispenser on the refrigerator.
Then it all made sense to me, as to why the water heaters in both of the homes we owned with softened water did not last as long.
