drain plug torque
Golden Meadow, LA
Can anyone confirm the oil drain plug torque for a 3.0 Vulcan, such as the one in my Ranger? Ive read everywhere that its only 10 foot lbs, does not seem tight at all. When i changed my oil last week, I converted it to inch lbs and put it at 120 inch lbs, so far it hasnt leaked or came loose but i just want to make sure 10 is the right spec.
Originally Posted By: Eddie
10 lb/ft is correct. I find that is good & snug for a leak free tightness. Ed
For that vehicle (10 lb/ft is correct) or for all vehicles (incorrect)?
30 foot lbs seems like a decent average to do by if one insists on using a torque wrench, but I was surprised to see a few vehicles with aluminum pans have torque specs near that.
Originally Posted By: shinyWheels
Yeah 30 is about what I use on in general. I'm surprised anything uses 10.
I'm surprised people torque their drain plugs
Everyone torques their drain plug(well unless they forget to tighten it), it's just that few of us actually use a measuring device...
10 ft lbs for the oem drain plug which probably utilizes a built in rubber gasket on the plug.
I also agree 30 ft lbs is a bit high for aluminum machined oil pans (Honda, etc). Its odd that the 30+ ft lbs is to crush the non reusable aluminum gasket but will not adversely affect the aluminum oil pan threads.
