Drain & Fill vs. flush of coolant system
Ormond Beach,FL
In a recent vintage car with long-life coolant, why would one flush the system vs. just draining and filling ( when it comes due) ?
I ask this question both for replacing with original car brand or changing to a different coolant ( such as G-05 or Peak Global,etc.).
Well, I'll take a stab at this since no one seems to want to. First of all, you say "recent vintage car". To me, that's a contradiction in terms. A vintage car is not a recent car.
If you have a drain plug or plugs at the bottom of the engine block you can remove them and drain the coolant out of the block. If you can drain the engine block as well as drain the radiator, you may not need to flush the system IF the car is new or fairly new. You flush the system for one or both of two reasons: (1) you wish to remove all the coolant from the system, which means you must remove it from the engine block as well as the radiator, AND you don't have, or can't find, or don't want to mess with, the engine block drain plugs, and (2) you wish to remove built up deposits clinging to the inside of the parts of the cooling system. With a new or fairly new vehicle you should not have these built up deposits.
If you switch from one type of coolant to another, you should be sure to get all the old coolant out before filling the system with the new, different type, of coolant, which requires you to either drain the block and radiator or flush the whole system, which flushes the old coolant out of the block and through the radiator and then into whatever you collect the flushed coolant in, such as a large pan.
(Wildly shaking hand and jumping out of desk in the back of the room as far away from the teacher as possible Obbop screams out....)
I might have anuddah' reason to flush vice drain/fill.
To assist in preventing cavitation, exposing innards to the atmosphere when they should only contact coolant mix.... to keep those pesky air bubbles out of thine cooling system perhaps a flush would assist in this.
My 1975 Honda Civic CVCC had a nifty little fitting at the topmost part of the cooling system. A quick turn opened that fitting, allowing trapped air to escape.
After a drain/fill it would take a few openings of the fitting to get every last bit of air outta' the cooling system. Eventually, no mo' escapin' air and my system was totally filled.
If your conveyance lacks such a handy device it MAY be better to use a flush vice drain/fill.
Just a guess.... do not take my output as cooling system gospel!!!!!!
