The internal bypass is designed to 'relieve' differential pressure when it get's above a spec'd pressure. With none there it will be relieved with next easiest path, that would be the media. In other words pressure would build on the media, possibly to point of blowing out the media. Then you're in perma bypass.
Also why bypass referred to as a pressure relief valve.
Sure there are more technical explanations, but from a practical stand point that's what could happen.
