Originally Posted By: SpecificationR
my rotella t6 5w40 has sheared to a 11.89 cst @100C. after 3000 miles and 4 qts of take up
At least mention how bad your tuning is and you probably had 2% or more fuel dilution.
You never see 5W-40 RTS shear that low on its own.
From looking at many, many UOA's over time, I've seen that RTS 5W-40 (not talking about T6) shears down to the 13.5cst range on average. Never less, sometimes higher. I can't call [censored], but there are a lot of Shell haters. I don't see how just RTS 5W-40 caused problems when in every single individual UOA, whether gasoline or diesel, turbo or NA, it brings back stellar results.
It was because of these results I started using it. It goes in a GM LS1 V8, a Ford 5.0 EFI V8, a Mitsu 2.4 SOHC 4 cyl, a GM 3800II V6, two lawnmowers, one pushmower, and a weed-eater. I believe that if this oil had a formulation problem, I would be the first to experience it. I am not easy on anything, and I actually am harder than normal on my vehicles because I think the oil is great.
