Does my engine have a maf or map?
Denver, CO
Hyundai gamma 1.6 di non turbo. I wanna use some seafoam intake cleaner and want to spray it into the throttle body. I can't see a maf sensor anywhere, where exactly would a map sensor be located?
A MAP sensor could be anywhere, though realistically they're on the intakes now. In the 80s they used to be on a vacuum hose somewhere.
Well if you can't find the maf sensor then you definitely have a map (and some systems use both). The map is located on the intake...where I'm not sure but a google search should give you a picture.
A manufacturer can change things like this if they choose to, as an engine family evolves over years.
You should have provided the vehicle model and year. Why would you not provide full info?
