What about purely inductive circuits? They, at least for the first 5 time constants have current flow "in" ..but no current flow "out". This also must lead some of you to plug in "power factors". Some have described this as "aerated water".quote:
If the mass of water in the hose is the same whether it is moving or not, the weight is the same.
I could be wrong, but I thought there has to be an equal current flow out for there to be current flow in. Voltage does lead current on an inductive circuit though: application of voltage results in a current that builds non-instantaneously (it lags voltage).quote:
Originally posted by Gary Allan:
Again ..you guys are way outta my league here ..but..
Comments??
I suspect the water is acting enmass, but in the electrical cable the electrons are all running their own little paths, thereby breaking up any combined inertial effect, probably because it is alternating current. I wonder if say 10,000 volts of direct current suddenly entered an electrical cable whether it would cause the cable to jerk and jump.quote:
Originally posted by Shannow:
[QBWhen I asked why they didn't have to put thrust nlocks on the corners when they ran a cable around a building, while I had to with water, whih is going 100,000,000 times slower, they just sat looking stunned. [/QB]
Weight and mass are two different quantities. Weight would be a function of the velocity of the water and radius of curvature of the hose as well as orientation of the hose relative to the Earth's gravitational field.quote:
Yes, ELI the ICE man (Voltage leads current by 90 degrees in an inductive circuit - current leads voltage in a capacitive circuit by 90 degrees).quote:
