A few days ago, I finished a complete rebuild of the front end of my '03 Ford Focus. New lower control arms, inner and outer tie rods, quick struts, sway bar bushings and end links. Not long before the rebuild I had the wheel bearings replaced at the same time my clutch was replaced. Everything is new and hopefully I can get a good, solid 10 years or so out of it.
The last step is to get the front end aligned and I'll be all set.
Out of curiosity, I went online to see what methods were out there to adjust the toe since I know my tie rod adjustment is off (I can actually see my drivers side tire is off) and I saw that there were people using the string method and others used toe plates (which is new to me) to get it adjusted so that they could safely drive to an alignment shop.
However, I saw that there were some folks out there that relied solely on their at-home alignment and said that their tires had normal wear and they corrected what their alignment shop was unable to correct.
That got me to thinking..........what are you all doing with regards to front end alignments?
