Finally! Someone asking this question! We've all wanted to know on this forum what the answer is!
Too long, didn't read. What is the answer?
Now here's a great and clarifying answer!Those are side issues. Wear comes from metal-to-metal contact so it is ultimately about keeping the parts separated due to the film thickness. This is represented by the HT/HS so yes an oil with a higher HT/HS "protects better" as it will provide a higher MOFT.
And better (or less) VII will contribute to shear stability but as we've seen here mechanical shear is rarely an issue. Fuel dilution is a far more prevalent problem.
The shop foreman at the Ford dealership my son works at, suggested that he use 5W30 in his 04 (new style) F150 Lariat, 5.4 3V engine. So, he does. His engine is very quiet.Just to echo your point, the Ford 6.2 in a F250 spec’s 5w30. In a F150, it spec’s 5w20.
My oil cap says nothing about grade. It just has Castrol on it that's it. When I look in manual it says use VW50200 5W-30 or 5W-40.Occam,s razor. No more assumption to a thing than what is necessary. The fill cap says 0w20, use 0w20. Fill cap says 5w30, use 5w30.
there isI’m surprised there is not a thicker ATF crowd here![]()
My oil cap used to say 0w-20 , now it says 5w-30.Occam,s razor. No more assumption to a thing than what is necessary. The fill cap says 0w20, use 0w20. Fill cap says 5w30, use 5w30.
How many beers when you heard the oil caps talking?My oil cap used to say 0w-20 , now it says 5w-30.
I heard it when i was out in the garage, getting a beer.
So, what do you use?My oil cap says nothing about grade. It just has Castrol on it that's it. When I look in manual it says use VW50200 5W-30 or 5W-40.
I wondered the same thing, but had not opened the can. So I lifted the hood , and before my very eyes, the cap went from thisHow many beers when you heard the oil caps talking?
Darn, we've both had too many... I'll drive.I wondered the same thing, but had not opened the can. So I lifted the hood , and before my very eyes, the cap went from this
To this!!!
Check OM viscosity call-outs for the same engine used in other countries.The manufacturer recommends 5W20 and may have designed engine operation around it. It did not recommend 5W30. /thread
5W-30So, what do you use?
