My only complaint is that I started to fix this thing and I am into it too deep!
. It should have been junked, and would have been if I'd known how much work I was facing.
When this started out it was only to be a timing belt kit. The next thing I notice is the water pump dripping. When I get the rear timing covers off, I see all the seals have been leaking.
Since the spark plugs have over 100,000 on them, I decide to change them. I find the spark plug tubes full of oil and the wires drenched. OK, so now I need to remove the valve cover. That requires removing the wiper tray, the coil, and the entire upper air plenum. That when I see the PCV valve and its never been changed because it is hidden and requires the air plenum be removed. I've go a cracked emission hose.
I remember the noisy lifters and since I have come this far, now is the time to replace them (I found 5 frozen solid). So to get to the lifters, the cams have to come out. Since there is a pretty defined groove in the cams where the seals ride, I put repair sleeves on those and on the front crank. Then we have a leaking oil pressure sending unit and on this car it is a PITA to change.
I probably should have put a reman head on it, but no more money will be spent. Oh.... I forgot to mention that when the tensioner failed the belt rode to the back and ate thru the rear timing cover so I have to replace it. This never ends. Only my persistence continues....
Thanks for letting me vent a little.
