I’d say 7 kw seems to be the most common installation around, at least where I am at 50 degrees north latitude and given “ average” sized roofs up here.7 kw solar power system
Me as well. Just a 200watt unit on the roof that serves me well because I don't go places without hookups.Only a panel on the RV …
In the past I considered one because there was a house near by that had one - but I never saw it run even on windy days. When I asked the owner about it he said it worked well for the first 2 years but then it broke (something in the gears) and the maker went out of business so he has not been able to get whatever he needed to fix it - so it just sits. He said it cost him around 15k after all the concrete, windmill installation and hookups were complete and it did power his entire house. This was all around 5+ years ago and it's still not running. So guess you have to be sure the company is solid and been in business a long time. He said the one he bought the company was only in the market a year or so when he bought.Does anyone have a residential wind turbine these days? They were a thing a long time ago but they broke and the companies went out of business.
Likely no longer efficient compare to the bigger ones. They are now go big or go home kind of install.Does anyone have a residential wind turbine these days? They were a thing a long time ago but they broke and the companies went out of business.
We could have gone larger, but I did not want the array to be seen from the street or be largely visible from the cove out back. Our installation was driven by the available subsidies which made the decision simple. We also went through an independent installer and own the panels; wouldn't even speak to the door-to-door solar reptiles.....with all due apologies to fine reptiles.I’d say 7 kw seems to be the most common installation around, at least where I am at 50 degrees north latitude and given “ average” sized roofs up here.
After watching several YouTube videos on this the conclusion was that unless you could get the windmill high enough to keep the trees from blocking the wind, it wasn't economically viable. Now if your area doesn't have trees you might have a chance..Does anyone have a residential wind turbine these days? They were a thing a long time ago but they broke and the companies went out of business.
Yeah, the taller the better for them.After watching several YouTube videos on this the conclusion was that unless you could get the windmill high enough to keep the trees from blocking the wind, it wasn't economically viable. Now if your area doesn't have trees you might have a chance..
Our last community, which is pre-retirement and larger homes. Solar systems were not allowed.We could have gone larger, but I did not want the array to be seen from the street or be largely visible from the cove out back. Our installation was driven by the available subsidies which made the decision simple. We also went through an independent installer and own the panels; wouldn't even speak to the door-to-door solar reptiles.....with all due apologies to fine reptiles.
