"a la Prestone Extended" Short answer, No.
Long answer, Prestone uses 2eha found in Dex and Dex Clones. The fact that is now contains some P means little to me other than it now being some type of modified Dex Clone. None of the Asian Phoat AFs use/contain 2eha, neither does G-05 HOAT. The latter of which Ford did/does not back spec those vehicles using it to it's newer Dex 2eha based AF. FCA/Chrysler OAT OAT AF also contains no 2eha.
Now there are many reasonable priced aftermarket vehicle specific spec AFs, ie., Asian Phoat AFs and G-05, no need to use a universal. If the vehicle specs DexCool now, use it, also found in aftermarket. Perhaps, one might consider Prestone Extended for DexCool applications, that might be the one application cross over I'd think ok.
Only AF I'd be comfortable with using in multiple applications like those mentioned, Peak Global Lifetime. Long service interval OAT AF, no 2eha inhibitor. I have used it with good success in Asian applications.
