Do ya'll think I'm going to be needing LC
New York
I'll be ordering FP to be used with Neutra as a FSC. I'm currently down to my last bottle of Redline S1.
Does anyone see any application for LC. If so, I'll order it along with the FP....but I don't see myself using it. Current car is BMW X5 4.4 V8 - 2003. I'm currently running Redline 5W30 and will do a used oil analysis off this run when I change the oil in spring. I plan to run another fillup of Redline after the oil change in spring and do a used oil analysis off of this also (this would make it the 4th fillup of Redline). After that I will try Mobil 1 Truck and SUV, Amsoil and also GC just to determine what works best in the car and stick with it.
Probably not but it can not hurt. I too use Redline and I am considering useing LC. I figure the added solvency and antioxidants can not hurt. I like the fact that I can use LC with any oil I use in any vechile I own. I can either use it to help control insoulable and oxidation at low treatment levels or at higher treatment levels it becomes an engine flush.
I am currently using it in all my vehicles and it seems to work fine. In fact, I am very impressed with its cleaning ability, even at low add levels. For some reason, most of the used oil analysis posted here with LC, look very good, although I can't say how much LC had to do with it. But like JB said......it can't hurt.
