Got a call from the local Ford dealership this morning regarding my Explorer. I do my own maintenance on it, but I was "threatened" that if they didn't see the truck periodically, I would lose my warranty. Only way around it is to take it to them and get them to do all the services I "missed".
Anyhow, the service adviser who called me asked for the mileage and I told him I was closing in on 30,000 km (18,750 miles). He said I have a "major service" coming up and should consider bringing the truck in. When asked what the "major service" at such low mileage was, he said the fuel filter needs to be replaced and the injectors need to be cleaned at the princely sum of $217 including the oil change.
Call me nuts, but I run Liqui Moly's Fuel Injector Cleaner at every second fill up. It has a high PEA content, and there's not even any carbon deposits or build up in my tailpipe. The engine runs smooth as butter, even when pushed to the limit (sees 6,000 rpm regularly), and I don't see anything about fuel injector cleaning at this mileage in the manual. I'm also running Euro V rated gas ($3.48/gallon) in this truck to protect the emissions system (10 ppm sulfur instead of 500 ppm otherwise).
I can understand the fuel filter, but do I really need to pay someone to pull the manifold off and run the injectors through a cleaning machine at 19,000 miles?
Anyhow, had a word with the service manager and said I would be happy to bring the truck in only if it was acceptable to supply my own engine oil (happy with the Motorcraft fluids and parts they use otherwise). They use Mid Eastern Castrol GTX 10w30 which "meets the requirements of API SL" with no ILSAC or any other accreditation. When the truck ran on this garbage, the engine was so loud it was unbelievable. The SM said he was happy for me to supply my own oil otherwise, but I'm still not entirely convinced they're pulling this warranty [censored] on me.
