OVERKILL
$100 Site Donor 2021
Did you read the line after that?Not here to argue with anyone. Here to learn or provide my perspective.
I've read numerous articles on the roles of detergent additives. While, yes, one role is to suspend contaminants, acids, etc. to prevent deposits and sludge (prevention being very important), a primary role is to clean surfaces of sludge, varnish, etc. Here are just two quick cites to support my informed belief.
Detergent Additives in Lubricating Oils | CompareMotorOils
These are ingredients of any engine oil as they help the engines by cleaning up the sludge and other deposits (which hinders parts functioning).comparemotoroils.com
"their first job here is to clean the metal components of the engine in order to make them free of any kind of deposits."
For example, they are used to clean the contaminants of the carburetor that could otherwise hamper its functioning.
Or the one after that?
Moreover, they are also found to be extremely effective in reducing the deposits of fuel injectors so the pattern of fuel spray does not get affected.
And then:
In addition to cleanliness, they are also used to counterbalance the acids that develop during the combustion of oil (as they have alkaline nature).
That whole article sounds like it was written by AI unfortunately and is conflating detergents in gasoline with those in engine oils.
The only correct statement is the very first one:
The fundamental function of these compounds is to suspend the deposit particles that could later be removed during oil interchange, they also counterbalance the acids that develope during oil ignition.
Which also reads like it was written by AI (oil ignition?! this should read combustion).
Detergent Dispersant is the Most Important Role of Oil Additive
Adding a small amount of other substances to the lubricating material can improve its performance and give it new characteristics. These substances are called oil additives.www.infomak.com
"main function is to keep the inside of the engine clean, so that the insoluble matter generated is in a colloidal suspension state, and it will not further form carbon deposits, paint film or sludge. Specifically, its role can be divided into four aspects: acid neutralization, solubilization, dispersion and washing.... carbon deposits that have been adsorbed on the surface of the component, and disperse it in the oil to keep the engine and metal surfaces clean."
That article doesn't read much better unfortunately.
These Lubrication Explained videos are pretty decent, here's a screenshot from the 2nd one:
Detergents:
Dispersants:
So, as I described, the detergents prevent these contaminants from plating out on surfaces, keeping them in suspension in the oil. Dispersants work similarly, bonding to the particles, but their main role is preventing agglomeration. Neither is designed to clean-up existing deposits, though dispersants, can, as I noted, work a bit on soft deposits as the oil flows over them.
