Posted before about my 2003 E450 box truck that's only been driven 600 miles the last few years and that the left front caliper is sticking. Replaced the brake hose and it's 75% better and it doesn't pull to the left anymore, but I can feel the left wheel much hotter than the right after a few miles drive. Lifted the wheel off the ground and I can't turn it. Opened the bleeder and no unusual pressure. So I take the wheel off and remove the caliper to check the slide pins. They are fine. Take the caliper off the hose and to the bench to take apart, Get the piston (plastic) out as well as the seals. Even with the seals out I can't press the pistons back in. Do they swell? Can I use sandpaper to reduce the diameter or will that just mess them up? A new pair is only $17.
