HTSS_TR
Thread starter
Took me a total 2 hours to replace front pads and flush the brake fluid on the 1991 Tracer. Brake fluid was flush for the first time last year, the bleeder screws was frozen when I tried to crack open last year, I had to use WD40 and wait 30-45 minutes to unscrew the bleeders. The fluid was pit black last year, this time it is dark brown. I used 1 pint to flush the fronts only. The Mityvac fluid extractor finish the flush in less than 5 minutes each side, I only pump 4-5 times to slowly extract brake fluid. Bleeding the brake system with Mityvac is as easy as eating pizza.
Overall, changing brake pads is not that difficult, only time consuming in raising the car and remove/reinstall the wheels. If I drive it to my mechanic to have it done, I would be spending 2 hours total(1 hour drive round trip and 1 hour work) and $100 for labor to change pads and bleed brake fluid.
