1997 Integra B18B1 engine
The Honda type (TEC) distributor has a bolt that hold the rotor to the shaft and it is common for this bolt to get stuck or strip the head. I'm not having this problem, as I've gotten it out.
The problem is that the rest of the rotor's metal collar are bind to the distributor's shaft instead. It looks like the shaft is mildly rusted, and I've sprayed PB Blaster there and tried to pry it out, but end up cracking the "Leak" cover (#6) instead.
I've heard everything under the sun including PB Blaster on the shaft, vice grip on the remaining rotor, soldering iron (to heat cycle the bind surface) instead.
What should I do next to remove it?
