Were transmission, Tcase and axle lubricants changed regularly? Admittedly I think torque converter failures aren’t uncommon in the GM units, but in my very limited experience, neither are transmission fluid changes among the owners I’ve known.
If 4wd was used regularly, the vehicle was seeing some use, and the Tcase chains do beat up on the small qty of lubricant when used.
I’d be disappointed too, but 130k miles would be about right if the fluids weren’t being changed out.
I’ve seen these trucks go farther without major failures like this, but the guys I know are pretty solid on oil changes.
And conversely in agreement with you, there are definitely problem areas for all trucks from the big 3.
