Quote:
I don't see why you are disappointed in a GEAR oil that you used in your MANUAL transmission.
Lets look at the Toyota Manual for what is required for my Manual transmission...
Oil Type: Gear Oil API GL-4 or GL-5
Recommend Oil viscosity: SAE 75w-90
Lets look at what I put in: (quote from the web site. Here it is;
Mobil 1 75-90 gear oil web page
When you go to that page, look at this;
Mobil 1 Synthetic gear Lubricant LS 75W-90 is intended for initial fill, topping-off or refilling differentials, final drives, transfer cases and
other gear applications where lubricants meeting API Service GL-5 and multi-purpose or mild EP gear lubricants are recommended
Mobil 1 Synthetic Gear Lubricant LS 75W-90 can also be used in rear axles where API Service GL-4 lubricant is recommended
Not recommended for automatic, manual or semiautomatic transmissions for which
engine oil or automatic transmission fluids are recommended
So, we have
75w-90 GEAR OIL, GL-4 or GL-5 , and my manual has NOTHING about engine oil or automatic transmission fluids.
Any comments so far?
I put in what is recommended and what Mobil provides.
Quote:
Maybe you should blame yourself for using the WRONG fluid for you application.
Again, I put in WHAT the MFG stated and what Mobil stated.
I used the correct fluid according to mobil. Its just garbage fluid.
Quote:
I also see that you ran the factory fill for 22k miles and the M1 for 43k(~65k total). It seems to me that you got your moneys worth. You ran it twice as long as the factory fill. What gives?
I was stating that according to Toyotas manual, the factory fill is just to be inspected, no note to replace unless you tow.
I consider a $10 quart of Syn oil lasting 43k miles and performing as it did to be POOR. Esp towards the end, it was performing terrible. Noisy and shifts becoming poor.
But I guess thats ok according to you. No where did I get my moneys worth here.
I prob should have run the factory fill to 65k and would have gotten better service than the 43k of Mobil 1.
Quote:
Also, without UOAs, fluid looks are meaningless. Sorry, what I see is M1 cleaning and dealing with the leftover from the factory fill.
I agree that a UOA would tell somethings, but the FACT that the oil was breaking down (
PLEASE will EVERYONE STOP with the CLEANING #@$%! )
and turned that color in a NON engine app and was performing like it was tells volumes.
If you really THINK that Mobil 1 was cleaning my transmission after 22k miles...
Knock off the koolaid...
Quote:
Mobil-1 makes no claims to being a GL4/GL5 manual transmission fluid for automotive use.
Sorry, their email to me when I asked about what oil to use in my 05 Corolla transmission is what I used.
Here is the info out of my manual just to make sure everyone sees it;
I stand by everything I stated in the first post.
bill
