Today I decided to finally change the diff fluid in my 03 Dodge ram 1500. It has the LS clutch pack and I decided to add 3oz of LS fluid with the Valvoline 75w140 Full Synthetic gear oil. My biggest concern was that I planned to use a gasket instead of RTV. I had Red and Black RTV but have found comments that using a synthetic fluid you need to use either the Dodge Orange or permatex Green because they are resistant to the synthetic fluids. I dont know if its true but since Permatex decided to create a special RTV for it I took it seriously. Anyway when I went to get some my local AAP did not have any but could order it for $14/tube or a Felpro Gasket for $7 so I picked up the gasket. I had the oil changed by the dealership when the truck was under warranty back in 2006 so I was surprised when I took the cover off and found Red RTV covered by Gray RTV. It looked like they made a half hearted attempt at removing the Red but where did the gray come from if it needed Orange or green. The truck only has 60k miles on it and I was worried about the clutch pack retainers that were known to break and fall to the bottom but I was lucky and everything was in good shape with only about 1 mm of metal sludge stuck to the magnet in the bottom. After I got everything cleaned real well with a scrubby pad and brake cleaner I hung the gasket on the cover with a couple bolts through the top holes and then just finger tightened them and added the rest the same way. Used a cross pattern to tighten them all to 20 ftlbs and then went back and redid them all at the 30 ftlb spec. According to FelPro no gasket dressing is required so I was crossing my fingers. Added the LS fluid and 2.1 qts of Valvoline and took it for a 15 mile drive. NO LEAKS SO FAR. So does anyone have any experience using Synthetic fluid and some RTV other than green or orange, what ever the gray is it didnt leak for 14 years and has anyone ever used the gasket instead of the recommended RTV.
